TT LS400 Prototype
#126
Impressive stuff Lextreme. Good to see things are coming along for your TT LS400. Are you planning to finalize the TT setup into a kit and sell them? Or will this be just your project for the time being?
Again, looks great and good job.
#127
MUCH better!!!
It looks like you have solved your oil control problem(s), and now your MAF situation should be very functional. My guess is it will feel even MORE powerful at a lower boost than it did before.
I know that your are looking to get the car dyno tuned soon so I won't hassle you about fuel and timing![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
The only things that worry me are the low air inlets than could VERY easily become water pumps... for the results of this type of condition please see my post on "Broken engine".
The other is you may want to add some sort of skid plate to prevent turbo and or oil system failure in the event of an aggressive speed bump or something to this effect.
#128
Low air intake is a problem. Few weeks ago, we had a very heavy rain. The inlets were sucking water in and my engine died few times. Water is not compressable and its very dangerous for the engine. I have tried to use an elbow and extend the inlet some near the shock area, but it rub when the tires are fully turn.
I have a good relationship with a local muffler shop, i can ask them to make a custom inlet pipe.
#129
Finally,
Got my Alcohol injection running properly. Right now, its being activated at 7 psi and I am running 8 psi. The car pulls very hard at 3k and above. Passing cars on the freeway is a piece of cake. WOT with Over Drive off. The car fly. Anyway, I painted my intake tube yesterday with the high temp spray. Check it out.
#132
Originally posted by Lextreme
Finally,
Finally,
One question, does the car sound a lot different from stock?
#133
Yes and No. Yes it does sound like stock if i did not change the exhaust; but i change my complete exhaust with two 3" pipes. It sounds like Chevy Big Block with turbos spoolings.
Yesterday, i pushed my car to the redline as I was trying to pass a semi truck going up hill while enter the freeway. The car pulls very strong to redline.
Also, late last night, I took my car out to a run down industry area. No police or cars around. I did some burn out. Smoke were everywhere. The tire marks were at least 100 feet.
That was the first time i ever did a burn out with an automatic tranny. It was interesting. I like to take a video of it some day.
#134
I too would like to see and hear your car, could you post a vid of it sometimes if possible?
#135
![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
I am very pleased you have stayed with this project. I know VERY well how frustrating this sort of thing can be. We definitely need to get some times on your car. I will let you know when I will be in LA.
