anyone got close up a pic of a broken t-belt? I think mine has 131K
Old 09-09-11, 09:45 PM
jtbel
jtbel's Avatar
That's what mine looked like before I changed it today.
Old 09-11-11, 01:21 PM
Cope
Cope's Avatar
I like to gamble, but I will not gamble on a timing belt with 131,000.
Old 09-11-11, 01:24 PM
Cope
Cope's Avatar
98 is interference
Old 09-18-11, 07:58 PM
RavenTai
RavenTai's Avatar
its killing me walking by my parked LX, such a tease
ordered parts tonight
BELT, TIMING
1356809070
$36.00 1 $36.00
CHAIN TENSIONER ASSEMBLY NO.1
1354050030
$38.00 1 $38.00
TIMING BELT IDLER SUB-ASSEMBLY NO.1
135050F010
$66.34 1 $66.34
TIMING BELT IDLER SUB-ASSEMBLY NO.2
135030F010
$66.58 1 $66.58
AIR CLEANER FILTER ELEMENT SUB-ASSEMBLY
178015001083
$21.64 1 $21.64
PUMP ASSEMBLY, ENGINE WATER
161005927583
$98.00 1 $98.00
Filters: Interior Cabin Filter-Cabin Air Filter
87139YZZ02
$25.19 1 $25.19
Drive Belt - LS400-Drive Belt - LS400
LSDB99
$37.00 1 $37.00
Floor Mat Retention Clips-Floor Mat Clips (pair)
FLOORMATCLIPS
$3.38 1 $3.38
Gasket (for oil drain plug)-Crush Gasket (Oil drain plug)
9043012031PC
$0.84 1 $0.84
Gasket (for oil drain plug)-Crush Gasket, (Rear Differential)
1215710010
$0.89 1 $0.89
Gasket (for oil drain plug)-Crush Gasket, Copper (Trans, ATM)
3517830010
$1.66 1 $1.66
SPARK PLUG, SK20R11
9008091180
$7.46 8 $59.68
VENTILATION VALVE SUB-ASSEMBLY
1220450020
$3.98 1 $3.98
Subtotal: $459.18
Tax: $0.00
Ground Delivery: $17.37
Grand Total: $476.55
almost ordered the two? fuel filters but did not want to put another $50 on the tab, when are these to be changed?
anything else while I am at it?
Old 09-19-11, 07:04 AM
deanshark
deanshark's Avatar
You should change the crankshaft seal while ya got everything off, ya don't want to tear it apart if it starts to leak afterwards. The camshaft seals are a BIG pain to change (have to remove camshaft) so if they're not leaking I would leave them alone. The fuel filter is supposed to last and last and last. That's why they put it up where it is so you can't get to it. Some people change them but most don't.
Old 09-20-11, 01:41 PM
RavenTai
RavenTai's Avatar
Ok gonna get the crank seal also, is the throttle body gasket reusable or should I get one? on my LX450 it was reusable, it was made of spring steel, I want to pull the throttle body off and clean it out.
Old 09-21-11, 01:32 PM
jtbel
jtbel's Avatar
On my '97 LS400, I believe it was a paper gasket for the throttle body (non re-useable).
Old 09-23-11, 07:28 AM
timmy0tool
timmy0tool's Avatar
Originally Posted by DonCorleone
95 and up are interference. I do believe VVTI=Interference.
i thought VVTI wasn't introduced until the facelift of the second gen LS which means it's 98 and up are interference. small difference but am i correct?
Old 09-23-11, 08:06 AM
deanshark
deanshark's Avatar
You're half correct about the VVTi, when it was introduced. But from 95 and up are interference.
The throttle body gasket on my 93 was paper but I think and suggest that the gasket should be changed no matter what it is.
Boredsoim1
02-15-18 09:13 PM
brent74
08-19-12 06:53 PM
GS_OREO
03-28-07 10:23 PM
XCGNT
12-28-06 04:06 PM
MikeGS4PE
Performance
05-23-02 12:34 PM
Quick Reply: anyone got close up a pic of a broken t-belt? I think mine has 131K
