My soon to be LS400 1999 107k
Old 09-29-11, 02:45 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
the proper way to do it is to have the CBEST setting reprogrammed...
Old 09-29-11, 06:10 AM
daweeze02
daweeze02's Avatar
I read that somewhere as well, but I don't want to pay for my dealer to do it.......will most do it for free?
Old 09-30-11, 08:14 AM
MicahBerry
MicahBerry's Avatar
While PD gave the proper method, I simply unplugged the steering wheel adjustment motors in the steering column. It took 10 minutes, most of which was spent getting the plastic cover over and off the little joy stick to move the steering wheel. Note that when you unplug the motors, you (obviously) loose the ability to adjust your steering wheel. So, make sure you set it where you want it before unplugging! My memory seats and mirrors still work, for those interested.
Old 09-30-11, 11:53 AM
daweeze02
daweeze02's Avatar
Funny you said that. I followed a diy for a SC to fix the gear but the LS is different. So while I was there I went ahead and unplugged it after setting it where I wanted it. I may just wire up a switch to turn it off and on if/when I want to move it. I also replaced the 2 bulbs in my 3rd brake light to fix the lamp failure. Then a locksmith came by today to cut my ebay key then I programmed it on the first try. So today has been very productive so far.
bluedeval0
09-08-15 09:31 AM
Lexxs048
06-08-14 12:58 PM
lexus1990
04-05-12 04:39 PM
willfitz69
12-01-09 08:59 AM
fatboyq
20
10-30-07 09:47 PM
Quick Reply: My soon to be LS400 1999 107k
