TRAC CHECK ENGINE TRAC-OFF light problem
^^^ thank you for your advice. I'm not retarded, I know the light comes on for a reason. all I said was that when I fixed "this" the light went away. so, by gods name, the thing I fixed MIGHT have had something to do with it. and actually, If your really want me to go into detail, my ABS sensor was recieving more than signal voltage, which means the ECU was putting out more than usual voltage, which mweans the battery voltage was low, due to lowe chrging voltage.... I'm ASE certified, as well as A-6 Basic auto eletrical certified.....
And how I drive my car is my business, I've been driving for 5-6 years, and have had 7 cars, which all did just fine.
Plus, you said "Had the same exact problem with my '91 LS400" How did you come to the conclusion that your alt was bad with those lights and those same exact codes?
dont know if I had the same CODES, but I had the same WARNING lights... whatever, I was suggesting a number of things he should check before making big purchases and spending money of fixing something he might not need fixed.
1badceli
Performance & Maintenance
01-15-06 07:25 PM
DroppedGS
03-16-04 12:43 PM
