Strut Rod Bushing replacement (Front Cushion UCF20 1995 1996 1997 Front knock noise)
Old 05-30-12, 04:12 PM
  #31
GaborL
GaborL's Avatar
Hey,
I looked at my bushing earlier today, and I saw that the rubber is almost completely gone, and I'm noticing a "wobbling" type shaking every time I brake and bring the car to a complete stop. I have a UFC20.
Any ideas where I can find the bushing by themselves?
I just called the dealer, and they said they only sell the complete arm, w/ the new bushing in it, and my shops price was about 160, while list price is somewhere 210, and I am not about to pay that much for a simple fix...
Old 05-31-12, 02:02 PM
  #32
billydpowe
billydpowe's Avatar
all you have to do is read this listing and your question is answered call SEWELL
Old 01-19-13, 07:07 PM
  #33
stanls400
stanls400's Avatar
+ subscribe
searching "strut rod bushing"
Old 05-02-13, 11:10 AM
  #34
Cowanhts
Cowanhts's Avatar
I just replaced the strut bushings on a 1998 LS400 (with Poly). I haven't driven much yet, but initial testing does show harsher ride over potholes, etc, and a harsher sound.
One thing I found during the replacement work though, was that the bolts holding the (old) bushings were somewhat looser than spec (121 lb-ft), especially on the right side. It's simple to re-torque these 22mm nuts (after removing the undercover) and I think these should be checked first. My most obvious symptom was a lot of creaking sound while turning sharply at low speed - primarily in parking lots. In retrospect, I think a simple tightening would have curtailed a lot of that creaking.
(I posted this on another Lexus site also)
Old 05-02-13, 11:58 AM
  #35
Lavrishevo
Lavrishevo's Avatar
Many owners have complained about poly bushes in the front. When I do mine I am going to use the Roca urethane for the front lower arms and use oem upper arms. You can buy OEM strut rod bushes from the dealer.
The Adus kit is what I will most likely use for the rear.
http://www.ebay.com/itm/ROCA-95-00-L...-/180806209201
http://www.armstrongdistributors.com/lexus.html
Old 08-27-13, 10:12 PM
  #36
Fullmetal
Fullmetal's Avatar
Are adus strutrod Oem bushings? They are not poly correct?
Old 08-27-13, 11:35 PM
  #37
PureDrifter
BahHumBug
PureDrifter's Avatar
ADUS are aftermarket, and are polyurethane.
Poly bushings do not work very well in place of the OEM strut rod bushings due to the way they are loaded up. I avoid them.
Old 08-29-13, 08:00 AM
  #38
Cowanhts
Cowanhts's Avatar
Default Avoid Adus strut rod bushings
As I posted, I installed Adus Poly bushings, and that was a mistake. Much too harsh. I bought a set of Roca bushings from Megan Racing, but haven't installed them yet. Unlike the Adus, they are very similar to the OEM bushings in design, and will hopefully be as smooth and quiet as the stock bushings.
Old 08-29-13, 10:58 AM
  #39
PureDrifter
BahHumBug
the OEM bushings are like $35-40/each. the adus are about the same price. unless you're building a race car there's no benefit to them.
Old 09-06-13, 11:53 AM
  #40
Hiroshi12
Hiroshi12's Avatar
Hmmmm, not sure where in CA you are but I just got a set yesterday from Lexus of Carlsbad and they were $62 each. Whole bar with new bushings were $153 each so even with paying a shop $10 each for the press - it's still cheaper. I'll take $150 over $300-plus anyday
Old 09-09-13, 10:41 AM
  #41
Hiroshi12
Hiroshi12's Avatar
Did my strut bars this wknd as part of the coil-over install. I got the rubber bushings from a local Lexus dealer and had them pressed in/out at a legit shop. Tabs were correct, torque was correct and this morning rolling out from the driveway...same clunk.
Old 09-09-13, 06:38 PM
  #42
PureDrifter
BahHumBug
then either:
a-you didn't torque the bushing end AFTER you lowered the car to the ground
and/or
b-it wasn't just the strut rods clunking...
Old 09-10-13, 07:59 AM
  #43
Hiroshi12
Hiroshi12's Avatar
then either:
and/or
...must be "B"
Old 10-27-13, 07:51 PM
  #44
Hiroshi12
Hiroshi12's Avatar
then either:
and/or
Just did the front lower bjs and tie-rods this weekend...let's see if the clunk is gone
Old 10-28-13, 10:06 AM
  #45
billydpowe
billydpowe's Avatar
keep us posted, is the clunk gone?????
Quick Reply: Strut Rod Bushing replacement (Front Cushion UCF20 1995 1996 1997 Front knock noise)
