Strut Rod Bushing replacement (Front Cushion UCF20 1995 1996 1997 Front knock noise)
Old 07-02-17, 03:40 PM
  #61
dashan
dashan's Avatar
Default Old bushings with 160K miles.
Old 07-02-17, 03:48 PM
  #62
billydpowe
billydpowe's Avatar
Originally Posted by Kansas
The terms "strut bar" and "strut rod" seems to be used to describe similar parts. I drove a generation one LS400 (1990) from new to 183,500 miles and never had a problem with it's strut bar/rod bushings. The strut bar/rod bushings on the generation two LS400 are a different matter and usually need replacement every 50,000 to 75,000 miles..
yep, Jim, I have replaced mine twice on my 99
Attached Thumbnails Strut Rod Bushing replacement (Front Cushion UCF20 1995 1996 1997 Front knock noise)-srbmk.jpg
Old 07-06-17, 10:31 AM
  #63
dashan
dashan's Avatar
The machine shop charged $20 to replace two bushings.
Old 07-06-17, 05:05 PM
  #64
dashan
dashan's Avatar
Old 09-18-18, 07:30 AM
  #65
Lovels400
Lovels400's Avatar
Where did you find the bushings? I can't seem to find genuine Lexus bushings and the dealer wants $350 for a pair of the bars with bushings installed. I did find a pair of arms on ebay for $225 but not sure if they are rubber or polyurethane bushings.
Old 09-18-18, 07:31 AM
  #66
Lovels400
Lovels400's Avatar
Old 09-18-18, 09:16 AM
  #67
bradland
bradland's Avatar
What year is your car?
Take a look at this link-
https://www.clublexus.com/forums/ls4...ew-in-box.html
Old 09-18-18, 10:00 AM
  #68
Lovels400
Lovels400's Avatar
It's a 99 but I ended up ordering the bushings from ebay. Got a pair shipped for $60. The guys that have used them say they are good.
Old 09-18-18, 12:28 PM
  #69
mikaelse
mikaelse's Avatar
Ok. 12 ton too weak! . I am happy then that I splurged 50$ or so and made a simple chinese hydraulic jack and threaded rods and
some wood press with 20 ton capacity. No problem getting them out and in. Have used it for other stuff also like bearings.
Old 10-24-18, 08:34 PM
  #70
valex
valex's Avatar
Default 1999 LS400 strut rod bushings
This is how the strut rod bushings look like on the inside. I had to press out the center out of the old one to use that outer sleeve to press in the new one in, since you cannot put pressure on the protruding center sleeve or will ruin the bushing.
Note where tabs are the bushing is solid hard rubber and the front and rear ( when installed) have some channels, with liquid, I guess.
New bushing have tabs marked in yellow and in the opposite side the tabs are reversed. I guess it doesn’t matter whether the tabs are at 6 or 12 0’clock. Correct me if I am wrong.
Old 10-25-18, 04:04 AM
  #71
billydpowe
billydpowe's Avatar
Plano Lexus
Old 08-06-20, 02:12 PM
  #72
Duarte
Duarte's Avatar
Originally Posted by PureDrifter
i'll confirm this procedure is the same for all 95-00 LS400s.
I've posted up tips/tricks in other threads but i'll repost them here.
-Use a jack to manipulate the spindle to make removing/reinstalling the strut rod into the LCA.
-make sure you put the strut rods into their respective sides, THE ARMS ARE NOT THE SAME. they are marked L and R. The bushings are the same for both arms.
-Torque big bolts TO SPEC! otherwise your alignment WILL come loose or something important will work its way off... a $20 torque wrench is better than your wrist, i almost guarantee it.
-the OEM bushings HAVE TO BE PROPERLY CLOCKED! Refer to manual, I believe the "tabs" in the bushing have to be 90* perpendicular to the arm, pointing down.
-DO NOT TIGHTEN the adjusters until the car is ON THE GROUND!! You need load on the arms so they reach their resting position before you torque down the caster arms or you may experience bushing accelerated ear/tearing.
-Avoid poly bushings, or at least know what you're getting yourself in to.
+a 24-36" 1/2 or 3/8" drive breaker bar WILL save your life.
Torque Specs:
+Shock to lower shock mount: 116 ft*lbf
height control sensor to lower shock mt: 48 INCH*lbf
+UCA Ball Joint: 48 ft*lbf (and replace clip)
Inner Shock bracket Bolt: 43 ft*lbf
Outer Shock bracket Nut+Bolt: 83 ft*lbf
+Strut Bar/Rod to LCA Nuts: 121 ft*lbf
+Strut Bar/Rod Bushing side Adjuster: 134 ft*lbf
anything with a + next to it is mission critical and should be within +/-5% to maintain both safety and keep the alignment. NO GUESSTIMATING!
How do we reach the lower control arm camber bolts with the wheels on the vehicle and on the ground on any of these low vehicles?
Old 12-07-20, 07:07 PM
  #73
Zaks
Zaks's Avatar
I've read the whole thread and have 2 unanswered questions... is the part # 48674-40051 good for 98-2000 LS as well or just 97 and older? Also, what is the part # for the control arm bushing?
Old 12-07-20, 07:57 PM
  #74
YODAONE
YODAONE's Avatar
Default Are 1995 - 2000 ls400 (ucf21) strut rod bushings liquid filled
1990-1994 Strut Rod busings are liquid-filled to promote damping.
Very robust.
You rarely hear about these failing...so Toyota earns a fail on the UCF20/UCF21 strut bar redesign.
Another post in this forum suggests 1995 - 2000 LS400 front strut bar bushings are Not liquid - filled, while here suggests they are.
Anyone have definitive Information?
Old 12-07-20, 08:16 PM
  #75
bradland
bradland's Avatar
48674-400051 works for 98-00.
Lower Control Arm (LCA) ...?
Quick Reply: Strut Rod Bushing replacement (Front Cushion UCF20 1995 1996 1997 Front knock noise)
