power steering fluid, need simple confirmation (read the bible)
![](http://i324.photobucket.com/albums/k359/niudude/downsized_1021011315.jpg)
93 ls400
ight so as the power steering bible says im having problem number 1 (whining on turns).
so i checked the fluid and it appeared to be bubbly and "soupy" but full, and the dip stick thing was fully covered.
is this normal?
Is it just air in the system? If so, to bleed that out you need to turn the wheel all the way one way, hold it a few seconds, then turn it the other way all the way for a few seconds. Repeat a few times.
so if i was to switch to the dextron or mobile atf, how would i go about draining out whats in there?
edit: found it.. will try to drain and put in the dextron
tanstaafl
ES - 5th Gen (2007-2012)
03-06-19 04:04 PM
RuninRoach
12-04-14 05:13 PM
ToyotaLexus
RX - 1st Gen (1999-2003)
02-12-09 10:05 AM
