Oil on my ac compressor
I noticed engine oil dripping from my AC compressor...what would cause that? Valve cover? My coolant is a little brownish too. And it is leaking from the coolant level sensor o-ring on reservoir tank.
Lots of places it could be coming from like valve cover gasket, upper oil pan gasket, cam seal, oil filter, oil spillage from adding a quart. What I first thought was the O-ring on the bottom of the dipstick tube. I've heard of a few leaking, including mine. Ya just need to get under there and look up. Follow the trail upward til it stops and there's your leak, the highest point.
Mine looks like someone mixed the OEM red with green and turned it brown. The compressor is above the pan and filter..maybe the vc is leaking and mixing with the coolant leak from the reservoir..I found a hairline crack next to the coolant level sensor on the reservoir..
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
Now that I look more where the A/C compressor is, it's probably either the VC gasket or cam seal that's leaking.
ayroman
02-19-11 07:14 AM
