Lowering a Strutmaster's Spring/Strut Conversion with Tanabe Springs
Hi,
I'm new to the forum (1st post).
I recently got a 1993 UCF11 Toyota Celsior and came across this forum when looking for support. The previous owner of the car replaced the air suspension with a Strutmasters Spring conversion. The car stands pretty tall (on stock 16" wheels) and I would like to lower the car using Tanabe DF210 springs, then add some bigger wheels.
I know the Tanabes will fit a stock suspension assembly, but the problem is that I'm not sure if they will fit on the Strutmasters assembly.
Has anyone ever done this, and can confirm if they work?
I live in the Caribbean, so buying, trying and returning springs is not an option for me.
Thanks,
Jonathan
Thanks,
Jonathan
A 2.5" drop is pretty aggressive with a stock like strut, there won't be lots of piston travel available. By the time you put new struts and springs, adjustable coilovers like Megan are at the same price point. Back some years, adjustable coils were north of $1,200 so springs and struts saved ~$300. If you were talking 1-1.5" drop with springs, the OEM type struts would be fine at that height.
Thanks for the response, I discovered that after doing some searching on the forum, and began searching for coilovers locally.
Down here, coilovers are a bit more expensive than springs/struts, but I think it will be worth it in the long run esp for the flexibility.
I also changed out my bumper lights and bought some 20s today.
Got some quotes for coilovers. Megans are the most expensive, then Ksport, with D2 Racing RS being the cheapest. I did not find any BCR. I'll look up some reviews for the D2s here.
my car is on megan and it rides pretty good. i am also on stock tires, its like rolling on balloons im sure its helping soften the ride. but sofar over all i am happy.
show us some pic's of your car x2
if i remember correct the d2's and ksport and made in the same factory...go with megan ez's, heard nothing but good from them, and for the price you cant go wrong. dont go with d2's or ksport is what sticks in my head from some of the posts i've read.
Are D2s really that bad? I've read some decent reviews on here.
The D2s cost $1kUS and the megan's cost $1300US down here.![Sad](https://www.clublexus.com/forums/images/smilies/sad.gif)
I do have access to used JIC coilovers, but I don't want to invest in used.
