Megan EZ's on UCF20/UCF21
0.5" front bumper from the ground? Or pinchwelds? I cant tell coz the headlights are blinding the photo
Post a daytime pic if you can. I dont know any UCF20 that low on coils, with their front bumper 0.5" off the ground. Hell i'm not even that low
And tucking rim on factory 16's?
curious to see the rears maxed out as well.
has anyone considered this: running the front struts on the rear and vice versa, but of course swapping the springs to keep the higher rates up front? i would think this would slam the rear, but the front may only go so far. according to megan's website the difference in length between the two is only 20mm (front 200mm, rear 220mm in length). swapping it would even it out eh? i would assume the shocks are not valved to be front or rear specific.
I'm trying to imagine how that would even make sense. The overall length of the shock is the issue. Even with a shorter spring you would still have to preload the shock and have no preload on the spring.
yes i know the rears are still at stock height. but just knowing how the fronts can slam the way it did with just the fronts on.. it gives me a good indication that i'm set to be slammed. here's pics of just the fronts with 3 inches of coils left. and to all you peeps telling me about the rears, i wouldn't doubt you guys. i've heard it many times again and again. let's see what i can pull off. if i can't get the rears to slam the way i want it.. i might possibly switch it backwards. ride quality sucks when you're slammed anyhows. i just don't want to be raked. i rather be a boat
