1992 LS400 Power windows and moonroof don't work
Old 11-05-11, 10:08 PM
kmoenck
kmoenck's Avatar
Default 1992 LS400 Power windows and moonroof don't work
At some point in the past couple months, all the power windows stopped working on my 92 ls400. Everything else seems to be fine (power locks, tilt, etc...). Fuses and circuit breaker appear to be ok. I have the wiring diagram and have tested power at the circuit breaker (ok) and power at pin 9 in the connector for the master control switch. With the key on, pin 9 has no power. I suspect the power main relay or the theft deterrent ECU that activates it but I'm having trouble locating the relay (not sure where to look).
Is there one relay that controls both the power windows and moonroof and if so, where is it? Or is there something else I should be looking at? Any help would be appreciated.
- Kaj Moenck
Old 11-06-11, 03:18 PM
vicious
vicious's Avatar
good q, my passenger window (93 ls400) switch is dying out.. have to use my drivers side switch to roll it down lol
Old 11-06-11, 03:44 PM
RA40
Super Moderator
RA40's Avatar
On a Nissan I once owned, the switch contacts had all kinds of carbon deposits on the contacts. This prevented the window switches from working properly. Maybe worth a shot to open the switch assembly up (if possible) and spray some electrical contact cleaner in there.
Silgs300
GS - 1st Gen (1993-1997)
07-22-17 04:59 PM
MattLS400
04-06-14 11:24 PM
Suapire
01-18-13 11:01 AM
blaktony
SC- 1st Gen (1992-2000)
06-06-09 07:03 AM
sj408
04-08-09 09:31 AM
Quick Reply: 1992 LS400 Power windows and moonroof don't work
