wrong temp reading
93 ls400
the reading for the engine temperature is fine but
the digital reading is wrong and i dont know if its messing with my ecu
it reads at 110+ on warm days (85) where is this sensor so i can fix
thanks for reading
thanks for reading
The ambient temp sensor is located behind the front bumper, I think passenger side. Usually when they go bad, or a short in the circuit, the gauge will read -22. You can check the circuit by=== http://www.lexls.com/tutorials/air/accodes.html
If it was ever unhooked you need to reset the gauge by pulling out the DOME fuse, under the hood, for 30 seconds.
Rokas
06-25-17 06:15 AM
sam12345
01-13-12 12:26 PM
tenchu
07-12-11 05:13 PM
