Mpg
guys stay on topic in terms of what the OP could do to better his mileage, we already have a couple dedicated gas mileage threads
OP-how do you drive? if you are driving at high rate of speed in hot weather with the AC on, consistently, then that's the mileage you're going to get.
is the OP even a person, that sn looks awfully vague and computer generated. from the united arab emerates?! but heck i could be wrong.
to answer the ? i get a mixture of 20-22mpg mostly highway on the weekends only. i drive 5 miles to work weekdays on a bone stock car. my rpm hardly ever goes past 2k rpms and the ECT is on NORM. i would check your driving habits.
im in the same position as the OP. car's mpg is shietty for a 99 ls400 with vvti. might have a vacuum leak from the brake booster cus the brakes gradually get stiffer when the car is off, does this affect MPG in anyway? lol
Its 12 years old, could be that the engine temp sensor is starting to go, making your car run rich as it always thinks the engine is cold.
Do you get white vapor from the tailpipes? Fuel smell?
I get fuel smell but not sure about white vapor, it's been cold lately. And my temp gauge works fine, but the car does take a while to warm up. If I let it warm up and drive for a mile. Itll be cold again After 6hrs of not driving and I would need to warm it up again.
