Stretched tires
Stretched tires
What is the point/benefit of stretched tires?
Dude, did you do any prior searching before making this thread?
People stretch tires to have more clearance from the fender when you're slammed. It allows you to run a wider rim and a lower offset rim and you can have more neg camber. It wouldn't hurt to search next time, there are hundreds of threads like this on many different forums that is accessible from Google.
BahHumBug
You should only be stretching your tires if you can answer YES to ALL these questions:
-Are my wheels a pretty aggressive fitment for my car?
-Is my car slammed??
-Have I rolled/shaved my fenders already?
-Have I pulled my fenders just a little (no paint needed)?
-Have I tried adding a little bit of camber (if there isn't much natural)?
-Am I rubbing against the edge of the fender a small amount?
-Will I only stretch enough so that I don't rub, NOT the most stretch possible?
if you can truthfully answer YES! to ALL these questions, congratulations you need to stretch your tires to some degree. Stretching tires for stretching's sake is a stupid idea and looks ridiculous (ever see a car that's too high/weak fitment will fully stretched out tires? yeah....).
Stretched tires = 3" + to epeen size
There is no logical reason for it (besides clearance) if that is what your looking for. It is highly unpractical and unsafe. Would I do it? if I had a second car that I don't drive much I would do it to that car.
Happy Holidays
I don't understand why you say it is unpractical or unsafe. Then unpractical is a bit confusing, but nothing i do or own is practical so ill go half/half on that with you. I have run stretched for 3yrs now, I have not increased "close calls" or been in more accidents since my tires got stretched.
This has been constantly attacked for the last few years. There has been no proof that a stretched tire is less safe than a non stretched. I have been to several tire shops and not ran into a problem because of stretch. I believe that if it was unsafe they would not install the tire.
PD I know you roll 20/9 f and 20/10.5 r, what offsets are you running again? I have been interested in some wheels that are 10.5 + 25 in the rear, and was wondering how it would fit and what kind of work may be needed. I have 10.5 +45 and run 275/30/20 right now.
BahHumBug
there is a logical reason besides clearance, ever noticed how almost all drift cars run stretch? When you spin a normal tire the torque of the vehicle tries to pin the bead of the tire faster than the tread. witch can cause tread sliding and other harm to the carcase of the tire. Also a stretched tire acts more as one piece with the wheel and does not have horizontal play. with this the tire will spin easier and longer in a sideways motion.
a VERY mild "stretch" is sometimes seen on autocross cars running smaller wheel sizes in order to stiffen the sidewall up a bit for response but otherwise not really.
