90 LS400 air suspension pump
one of the air struts in the rear started leaking. Initially the pump was working trying to pump it up but now I dont hear the pump.
Would someone be kind enough to let me know where the air pump for the suspension is located, more over is there a way to check if the pump is still functional before I get another one ?
thanks much.
thanks much.
sorry I dont know the wiring of it
maybe another member can chime in?
but from past experience I know that the pump gets tired from trying to pump up the bad bag, and then stops trying. after you restart the car sometimes more then once it will work again, try going to the trunk and flipping the switch for the air ride off then on again, that should restart the pump.
User21c
GX - 2nd Gen (2010-2023)
14
06-25-18 09:13 PM
Jason76722
02-09-13 11:48 PM
evan9r
12-18-07 01:14 AM
