P/S Help!!!
P/S Help!!!
Merry Christmas everyone! Well I had some time today to finish with replacing alternator and rebuild power steering pump. All I had to do was put it all together. Everything went together nice which I never expect. I filled the P/S reservoir with ATF. I finished and rechecked all the connections and all looked good. It fired up fine and runs well, I then begin to bleed the power steering pump by turning the steering wheel back and forth and nothing. No power steering at all and I am not even getting a moaning sound from the pump. I check the reservoir and it is still full. Some bubbles are coming out but only a couple. I rechecked the belt and made sure I have it running according to the diagram and the pump is turning smoothly. What am I missing?
Thanks Steve for your help. I bought it rebuilt. Could it be that they screwed it up? If I turn the shaft, shouldn't it have some friction to it since it is circulating oil. This one turns freely with no friction at all. If i take off the high pressure hose would I feel suction at the pump while turning the shaft?
Well I finally got it off and checked all my connections and everything looks good. Can it be that the pump is bad? What is that leaks the most on the pump? Is it the o ring from the high pressure side hose? I can get one and replace it?
It seems odd that they could rebuild a pump so badly that it would not work at all. Almost impossible.
You should see a whirlpool in the reservoir when it's working. If you're just seeing bubbles, something is wrong.
Thanks for the info oldskewel, I looked for that whirlpool affect in the reservoir but only saw a couple of bubbles. I wonder if I could swap some of the gaskets on this so called rebuilt one that is worthless and use the old one which worked fine just leaked. Are there any that you think that I can take off of this one and put in mine?
Thanks
Thanks
Thanks
Thanks
From rebuilding the pump in my '91, I'll say that it was straightforward, but took the right tools and was one of the more challenging things I've done on a car (and I've rebuilt engines and other stuff like that). Not too hard, but not forgiving if you make a mistake.
Yea, something is not making the fluid flow like it is suppose to. I looked at the rebuild thread several times and don't know if I should do it. Yes the pump is returnable and I am going to give it back but this car has been down for some time and i need it running asap.
I decided to just replace the o-ring at the high pressure hose and put the original pump back on and it works fine. I cannot believe I got a bad pump. I will now keep an eye on it for leaks and hope there are none. If there are I will get a pump locally and do it quick before it destroys another alternator. Thanks for all the help.
gtmuggs
10-10-13 09:01 PM
BrittonJ85
04-28-10 10:39 AM
