BBS CS5 Wheels
Check out this pic. http://www.tirerack.com/wheels/Wheel...All&sort=Brand
According to Tirerack this wheel fits Gen I LS400 but it doesn't fit 98-00 LS. But I just wondered why that is the case.
The specs are as follows:
Offset: 42mm
Backspacing: 5.86"
Bolt Pattern: 5-114
any idea why it doesn't fit?
Offset: 42mm
Backspacing: 5.86"
Bolt Pattern: 5-114
sorry, when i responded i was on my iphone and didnt count the number of spokes? or whatever youd call them. mine have fewer, but are still a 5-bolt pattern and are identical in all other aspects. pics here. https://www.clublexus.com/forums/ls4...er-w-pics.html
I guess I need to find out what kind of spacers I need to clear the big brake calipers. Tire rack don't like to recommend spacers. Any idea? Thanks in advance for your answer / thoughts.
generally, you'd need a 15mm spacer to clear. just buy a set of wheels that fit.
OK..... that seems clear enough. I ll walk away from this. they were so nice though........ my search continues.......
