DIY Brake Pad Replacement/Sensor Fix (UCF20)
Old 10-18-18, 09:31 AM
Jake28
Jake28's Avatar
Thank you so much for the tutorial-pictorial Heavy!!!
Just joined Club Lexus and am doing the rear brakes on my sons 2000 LS 400 and this write up with make things much smoother
Thanks Again Heavy
Jake28
Old 10-19-18, 11:22 AM
dveneman
dveneman's Avatar
There is a 3rd way to fix the sensor. I managed to "bridge the gap" on the tip of the sensor with a little soldering work. This way it should signal again if the rotor wears through it.
Yes, thanks Heavy for the 7 year old tutorial.
TurboTodd
10-26-23 04:19 PM
grandamliz
Suspension and Brakes
109
06-18-17 11:00 AM
speedkar9
04-15-14 03:35 PM
wolfalp159
GX - 1st Gen (2003-2009)
12-02-12 03:58 PM
Quick Reply: DIY Brake Pad Replacement/Sensor Fix (UCF20)
