key gettin stuck once car is off
i just picked up a 97 ls400 today. when i turn car off and try to pull key out it gets stuck so it wont come out. the old owner said turn the key real fast to the right like where ima turn the motor over and turn back to left and pull out quickly. thats only way i noticed key would come out. this is the stock key to the car as well not aftermarket key. does anyone know why this is happening? thanks
ok so today i tried taking key out. while i barely turn my steering wheel left and right and it didnt work. if i put key in ignition and turn to on position i can take the key out fine. but if i turn the car completely on where the motor is on then turn key off. i cant pull the key out at all. so i gotta turn car off. then turn key all the way to right where the starter pretty much trys to turn car on then turn key quickly back to left and pull out. this weekend i will try to lube the key and really hope this is the problem.
I too may be able to make a suggestion, In my 93 celsior i have an issue with my ignition and i have found it to be linked to my shifter. If I dont make sure it is all the way in park the key wont turn all the way off , just enough to stop the car not enough to remove the key. If this happens i turn the key back "ON" and push the shifter forward ever so slightly and you can hear a click, then the key can be turned "OFF" and the key can be removed. Maybe you have the same issue??? Anyone else have the same problem or hear of it. No big deal kind of annoying though.
jtmack
02-13-14 03:37 PM
MYO4LEXUS
08-25-11 08:16 AM
