VIP material!! 1998 LS
i've never seen the 97 LS400's even the coach edition with the woodgrain steering wheel and shift ****. almost all of the LS400's from 98 and up have the woodgrain steering wheel and shift know but there is some exceptions for the very early 98 models that have the year 97 in the door jam. i think they just simply didn't put the right one on when they gave it to us because the were being careless. woodgrain shift **** doesn't bother me that much because it's easy to replace.
I want to start with lowering and interior trims, the rims are the biggest chunk and the ones i'm looking at are around 1,500-3,400. my ideal rims would be work eurolines!!
He's got a UCF20, unless he's got air suspension...
https://www.clublexus.com/forums/ls4...signation.html
What would you prefer I call the facelifted model so you don't flame me in the future, sir?
You going with air or coilovers?
ksport is among the least popular LS400 coilovers of the options available. They have a history of premature damper failure as well as issues with the spring seats loosening/clunking. This was especially noted in the ES forum iirc and the Sylvia/240sx community.
for the '95-00 the most popular choices have been (in order)
-Megan LP/EZ coilovers
-BC Racing Coilovers
-Tein Cruising Master coilovers (less popular in the past few years though)
majority I would have to say are on Megan, and we love them
Yeah, I was referring to K-Sport Air Suspension. All I hear if positives; hell, a couple people running Air Runner and UAS have said they're switching to K-Sport because they could have the luxury stock feel or a very stiff track response.
I'm pretty much set on going K-Sport/AirForce myself this summer, then getting some 20x10/12 Ordens or Kranze LXZs by the winter. I was thinking of doing Meagan coils for a while, but decided that living in SoCal and having to trek out to LA to chill with Royal Flush on a usual basis requires a bit more clearance. With the K-Sport kit I can just roll static and raise up the suspension when I need to. Plus, at a couple hundred under $4G, can't really be beat. Unless you go custom or UAS.
Vip isn't as expensive as most people make it out to be...
lets be clear, ksport air/airforce bag kit are not in any way "static". you are running a bag on coil, so it is basically stanard air suspension with adjustable brackets and damping.
closest thing to static with clearance is coilovers and a cup kit (like the Phantom cup kit by Platinum VIP).
Your explanation seems to makes the most sense of them all proving a lot of naysayers that you do run air 24/7 in this kit, as there is no spring. Correct?
