will coilvers from 90 ls400 fit my 97 ls400
yes, i read that a ucf10 would fit a ucf20.
BUT! you would not be able to raise it up soo high (for whatever reason you wanna raise it up) because the overall length of the struts of the 10"s are shorter than the 20's.
I am not 1000000% sure, but that is what I understood.
Try searching it, it has been covered before I believe (key words: ucf10 ucf20 coilovers)
good luck!
good luck!
i was plannin on using the megans for a while then puttin uas on the car using the megan struts. so i guess shorter would be better cause i like to ride pretty low. i feel my car now is more like a boat lol.
if you put the 90-94 on the 95-97 it should be really low. i did the opposite and at max height i was still 2-2.5 inches lower than stock (90 ls400 with 95-97 k-sport kontrol pros- pretty stiff, but it was a sweet handling ride)
j three
03-28-16 10:22 AM
S30ZG
08-16-11 11:00 PM
