common causes for high idle 92 LS400
Old 02-04-12, 07:32 PM
benjanet
benjanet's Avatar
Default common causes for high idle 92 LS400
My tach doesn't work (dont worry we are addressing that in a the BIG cluster thread), but my idle speed feels high and I get harsh gear engagement.
Engine runs beautifully with around 150k miles on it.
Obviously I am going to check the IAC for cloggage.
Any other suggestions?
Old 02-04-12, 11:03 PM
GS4_Fiend
GS4_Fiend's Avatar
IAC first. start there.
Old 02-05-12, 09:40 PM
LScowboyLS
LScowboyLS's Avatar
IACV is the most common cause, you can get a used Idle Air Control Valve on ebay for $50 - $75 or it could be something as simple as a vacuum leak or the Engine Control Temp Sensor
my IACV was not clogged, it was stuck, and no amount of cleaning or soaking in solvent was able to unstick it
Old 03-07-12, 08:06 PM
Mark55
Mark55's Avatar
Do you suppose this could also affect a 1995 model as I'm having high idle issues as well?
porshapowe
14
03-21-19 09:21 PM
arredxndo
03-14-19 04:17 PM
wan8dan
09-17-14 07:46 PM
Lexus082
Performance & Maintenance
07-31-07 09:23 PM
gsimba
10-07-06 04:20 PM
Quick Reply: common causes for high idle 92 LS400
