Source of engine oil leaks
Old 02-09-12, 10:33 PM
moat
moat's Avatar
Default Source of engine oil leaks
I like to understand better sources of engine oil leaks for first generation LS. Besides the two valve covers (including those 4 little semi-circle plugs), two cam seals, one crank seal, upper and lower oil pans, where else could engine oil leak from? which are the common ones?
Old 02-10-12, 12:31 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
rear main seal
and that's pretty much it. anything else is abnormal.
Old 02-10-12, 01:34 AM
PK_Celsior
PK_Celsior's Avatar
possible power steering hoses xD just a though
Old 02-10-12, 03:02 AM
PureDrifter
BahHumBug
not engine oil...
Old 02-10-12, 08:54 AM
moat
moat's Avatar
Originally Posted by PureDrifter
rear main seal
By "rear main seal", you mean the output shaft seal right? (a.k.a. transmission extension housing seal)
Also, is it pretty common for those four semi circle plugs to leak after 200k miles?
Old 02-10-12, 09:05 AM
PureDrifter
BahHumBug
if they aren't messed with they should be fine.
Hiroshi12
26
12-23-16 02:59 PM
whitels
RX - 1st Gen (1999-2003)
04-23-12 12:56 AM
hoonami
02-24-09 01:57 PM
XYZLexus1
04-30-07 01:30 AM
novalogic8
Maintenance
02-13-05 07:06 AM
Quick Reply: Source of engine oil leaks
