Speedometer works intermttently
I actually took my alternator out a few years ago, because I was SURE it was causing a low battery voltage problem, after making dozens of measurements. Guess what? It turned out to be an intermittent bad cell in my 1-year old battery. Boy, was I mad at myself, because that's a lot of work. With over 100k on the car, I figured I should at least replace the brushes while I had it out, so I took it apart. Brushes were only 30% worn, and they are hard to find, so I just put them back in. The reason I mention all this is because I see several posts about how leaking ATF has ruined so many alternators. The Denso alternator is extremely well made, and it is much more likely that the fluid has only contaminated the brushes or slip rings. I would bet that you can simply clean any gunk from the brushes and the inside, maybe polish the slip rings with very fine sandpaper, put it all back together and get it tested for free at one of the auto parts places. AFAIK, there is nothing else in the alternator that would be impacted by any auto fluid; windings and diode packs should not be phased by it (unless it gets so clogged with debris that it overheats). It's certainly worth a shot.
Steve
Steve
SC4n00b
Performance & Maintenance
08-15-06 08:36 PM
