Speedometer works intermttently
The speedometer on my 94 LS400 works intmittently. Everything else works fine(tach, cruise, lights, ect) but the speedometer quits every once in a while anyone have any ideas what to check?? I am new to this forum and have never been on one before, so maybe I'm doing this right.
My guess is a dying #1 or #2 speed sensor. Trying checking for any codes: http://www.lexls.com/tutorials/intro/codereading.html
Before I was able to repair it and now that you say this I believe it may be tied into that, because that is when the problem started. What is the problem with the alternator and how is this tied in with the speedometer?? Do I need to replace it or is there another remedy? Thanks for the advice please reply asap. Tom![Egads!](https://www.clublexus.com/forums/images/smilies/pat.gif)
:hail:
The power steering fluid leaks into the windings of the alternator and slowly the alternator dies, as it does it won't be putting out the correct voltage to start the gauge motors..and eventually other motors like the blower fan. You need to replace the power steering pump and alternator if this is the case...you *may* be able to clean the alternator...and replace the correct o-rings in the pump. I waited to long and my alternator died completely...
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
It's a PAIN to remove when it's covered in fluid!
I had to loosen the power steering pressure line (I think) that is attached around the oil pan, then unbolt the alternator, pull it off the studs, then twist the alternator to get better access to the wiring. It's tough to hold onto and see what you are doing when it's covered in fluid.
I'd be surprised the vacuum hose (or whatever you plugged) was the only leak on the pump. These pumps are notorious for leaking when the seals/o-rings get old. I'd probably rebuild it and/or get another one while you are at it.
As far as cleaning the alternator...that was just a suggestion. I have no knowledge of anyone being successful in that endeavor.
I actually took my alternator out a few years ago, because I was SURE it was causing a low battery voltage problem, after making dozens of measurements. Guess what? It turned out to be an intermittent bad cell in my 1-year old battery. Boy, was I mad at myself, because that's a lot of work. With over 100k on the car, I figured I should at least replace the brushes while I had it out, so I took it apart. Brushes were only 30% worn, and they are hard to find, so I just put them back in. The reason I mention all this is because I see several posts about how leaking ATF has ruined so many alternators. The Denso alternator is extremely well made, and it is much more likely that the fluid has only contaminated the brushes or slip rings. I would bet that you can simply clean any gunk from the brushes and the inside, maybe polish the slip rings with very fine sandpaper, put it all back together and get it tested for free at one of the auto parts places. AFAIK, there is nothing else in the alternator that would be impacted by any auto fluid; windings and diode packs should not be phased by it (unless it gets so clogged with debris that it overheats). It's certainly worth a shot.
Steve
Steve
