Wilwood 6-piston Setup...
This setup should fit the 89-94 LS400's...on the '95's and up, we will have to test fit to make sure it works...
However, you will need AT LEAST the stock 17" GS wheels. IT will NOT work on the 16" wheels. We decided to cut the lowest common denominator as it would hold back the performance.
https://www.clublexus.com/forums/sho...threadid=62047
Hehee...there is no "group buy" per se...just a "pre-sell" buy...after that, the price goes back up to the normal price of $1995.
So long as you have the same inner diameter as a 17" GS wheel (anything over 17" should) and your existing wheels clear your existing calipers, you should be fine...
jtgs400
Wheels, Tires & Brakes Forum
10-25-06 10:46 PM
