Transmission Help
Hello
My 95 LS tranny is gone and it has an A340 in it I found a A341 from a 93ls on craigslist for pretty cheap
The question is will it fit and whats the difference
Any help would be great
Thanks
Sean
Thanks
Sean
I hear you lol Other than gear ratios I dont know either but I'm in a bind Do I shell out more money or drive my wifes mazda6 lol
Where did you read that at the differences
It was a post on here and I'm having a hard time finding it. From my understanding the physical dimensions were the same but the electronics and some kind of auto transmission part, maybe valve body, were different.
will bolt on, but won't work right.
plus you'll have multiple CELs. and will fail emissions.
use www.car-part.com and find a proper '95 or '96 trans.
How much would you pay for a used one
I found this Trans Although it was from a Jeep Cherokee it still has the same# as my car A340E
Will this work??
http://atlanta.craigslist.org/nat/pts/2856862721.html
Will this work??
Will this work??
I can't see how this would work because the electrical connectors for the vehicle options wouldn't be the same as what would be on a Lexus. Also, are you completely sure that the transmission is toasted? Sometimes it may need a component replaced or just need a good thorough cleaning
may want to look into a transmission rebuild kit.... i'd much rather rebuild a tranny than goign out and buying a used tranny which may have the same problem in the future....
just my 2 cents.
just my 2 cents.
