Power Mods for ALL years LS400s
Old 10-25-02, 12:17 PM
JBrady
JBrady's Avatar
Default Power Mods for ALL years LS400s
New member NJCasper from somewhere in Texas posted the following in the handling section and I decided my answer should be here:
NJCasper
I just bought a 97 LS 400 and would like to know if there are any performance mods I can do. Both to the suspension and acceleration?
jbrady
NJ,
Welcome to Club Lexus.
I used to own a 96 LS400 which is mechanically identical to yours unless you have the adjustable suspension.
There are many posts on performance and handling. One of the best is just lower the car.
I have an air filter box mod and an exhaust mod that a couple others have tried and reported excellent results. Read through the main forum and the engine forum and ask specific questions and we will try to help all we can.
NJCasper
Thanks for the info, I couldn't help but notice that when you search for performance mods the years between 94-97 seem to be non-existant.
jbrady
NJC, some mods help these cars, others can actually slow them. The air box mod I have on my 99 would be identical to a 97 and in fact the extra cover that I source to modify was from a 97.
The muffler mod is also identical. With the airbox and muffler you will pick up 10-15hp.
Lowering the car will improve aerodynamics and will free up a good 10-20hp... the result will be just like making that much more at the motor.
The exhaust system for years 1995-2000 is identical. I am working on a complete cat back system. Don't be fooled by the claims of most Lexus systems being "cat back". A true cat back must replace the restrictive Y-pipe and center resonator on our cars. Done properly there should be 15-20hp in a complete system.
The next step would be a limited slip differential. I am trying to determine if the LS uses the same speedometer sensors as the GS. I have been told that the GS uses the ABS sensor for its speedometer and therefore changing rear gears does not change speedo or odo readings. If this applies to the LS... the 3.77 gears from the Supra non-turbo with optional LSD would be a considerable improvement giving over 15% more torque to the wheels on 98-00 models (4% on 95-97 models) AND providing double the traction.
I am also considering building a Cold Air box for the filter that will add an additional source of cold air.
All these mods are VERY smooth and Lexus like and should give up to 35hp.
I would LOVE to find a way to increase the rev limiter to 7000rpm.
Old 11-01-02, 01:53 PM
v8huntr
v8huntr's Avatar
i have computer upgrade is will give 15-25rwhp. i have made 22rwhp on stock ls400.
Old 11-01-02, 06:22 PM
JBrady
JBrady's Avatar
PLEASE email me all the details.
How does it interface? Features? Cost? Rev limiter? Availability?
What year LS400s? What were your before and after dynos? Can you post the dyno sheets?
Old 11-01-02, 06:24 PM
JBrady
JBrady's Avatar
Default Re: Power Mods for ALL years LS400s
I am looking strongly at the Powertrax positraction www.powertrax.com and the 95-97 LS400 3.62 gearset... if I can determine how to get the speedometer/odometer correct I will do the gears for certain.
Old 11-01-02, 07:15 PM
retrodrive
Search Function Inc.
retrodrive's Avatar
jbrady, check this:
http://www.cureline.net/lex/performance/ecu_ad1.htm
It's been on my site for ages!
Old 11-03-02, 03:50 PM
JBrady
JBrady's Avatar
Originally posted by retrodrive
jbrady, check this:
Retro, I had forgotten about that. Thanks for re-posting. Do you have this on your car?
Old 11-03-02, 09:41 PM
retrodrive
retrodrive's Avatar
Nop, since I am going with turbo or supercharger, I don't think I will need it.
Old 11-04-02, 11:57 AM
JBrady
JBrady's Avatar
I am concerned about the interface. I don't want to cut wires on my harness. If I can get connections so that I can "plug" it in then it looks very interesting.
Assuming (big if) that is not a problem then the first step for me would be to get a baseline dyno with A/F ratios. I suspect they will be on the rich side. This would definitely give room for improvement. I could either lean out the car as is OR build a higher flowing intake tube with a larger diameter MAF. This will lean out the mixture by nature of more flow vs. the MAF reading. Maybe TOO lean. Therein lies the opposite use for this device and that would be to richen it to safe levels.
Ice-Tray
Performance & Maintenance
16
10-18-08 08:16 PM
VVT-IS350
11-10-07 03:28 PM
persian451
12
03-29-03 03:11 PM
NJCasper
10-25-02 12:12 PM
Sc_300_Dude
08-23-02 01:36 AM
Quick Reply: Power Mods for ALL years LS400s
