Harbor Freight tool for lower ball joints
Old 03-08-12, 05:33 PM
Eds98LS
Eds98LS's Avatar
Default Harbor Freight tool for lower ball joints
I'm on mobile so I can't link the picture but HF sells a ball joint puller that's between the fork and the ones you attach to a socket. This one's in the middle and uses a nut you tighten with a wrench.
I am thinking about buying it to try and save the rubber boot on the tie rod.
I've had HF tools not work before so I wanted to check here and see of anyone has used before or if the autozone rental isn't all that bad?
Thx, Ed
Old 03-08-12, 05:37 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
you could use an HF tool but if you only need it once there's nothing wrong with the Autozone rental.
Old 03-08-12, 06:00 PM
Raddison
Raddison's Avatar
Harbor Freight 'till the day I die.
Old 03-08-12, 06:03 PM
timmy0tool
timmy0tool's Avatar
it's called a pitman or tierod end puller. i'm guessing the HF and the autozone one is probably made in the same factory in china. i have one from autozone, just bought it after doing so many axles on my honda, and it works really well. i say rent it, if used sparingly.
btw, never EVER use the pickle fork!
Old 03-08-12, 06:14 PM
PureDrifter
BahHumBug
different castings/companies but same idea and both made in china.
Old 03-08-12, 09:41 PM
LiCelsior
Retired
LiCelsior's Avatar
i use the autozone OEM brand pitman puller. works fine.
Old 03-09-12, 12:57 AM
Shiryo
Shiryo's Avatar
Why not just hit it with a hammer, that's what I did. I know you can possibly damage the threads, but it'll save your ball joint boot.
Old 03-09-12, 02:31 AM
PureDrifter
BahHumBug
using puller properly doesnt do any harm to the ball joint boot..
Old 03-09-12, 05:39 AM
Eds98LS
Eds98LS's Avatar
Here's the one AZ showed me they rent
http://www.harborfreight.com/11-3-4-...ator-1740.html
And here's the one I was going to buy (then take back later ;0)
http://www.harborfreight.com/3-4-qua...tor-99849.html
I'm honestly not <i>too</i> worried about messing up the boot b/c odds are I'll be back soon for the upper (car is 143,000) and will probably do a lot of stuff at that point. I do miss working on my cars though!
Old 03-09-12, 06:41 AM
PureDrifter
BahHumBug
autozone rents several pullers, but they arent all called the same thing.
try asking for a pitman arm or tie rod end puller.
the one LexLS used in his tutorial (but then removed when he updated with amazon links) was OEM#25297 from autozone.
Old 03-09-12, 01:06 PM
timmy0tool
timmy0tool's Avatar
autozone tierod end puller.
Old 03-09-12, 01:17 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
hit it with a hammer... not the ball joint, but a solid one or two hard hits on the arm will pop it free... don't be a wuss about it... we replace ball joints on a number of vehicles daily and NEVER use a puller to loosen the ball joint from the knuckle...
Old 03-09-12, 03:10 PM
bauceLS400
bauceLS400's Avatar
I bought the same one, it works perfectly. I used the fork and it damaged the boot. It was only less than 15 bucks.
Old 03-09-12, 03:54 PM
PureDrifter
BahHumBug
with the cost of ucas for these cars im not taking any chances lol.
Old 03-09-12, 05:10 PM
timmy0tool
timmy0tool's Avatar
even with these pullers, i still use a mini sledge to shock the knuckle to break the ball joint free. never EVER hit the ball joint itself or a weaker metal like the UCA!
Quick Reply: Harbor Freight tool for lower ball joints
