Car will not shift into certain gears (the gearshift wont)
Old 03-16-12, 04:40 PM
turbo556
turbo556's Avatar
I just need to know if the PNP is the same part as the one thats listed on Rock auto called the "Neutral Safety Switch / Range Sensor"
Old 03-17-12, 03:36 PM
Luxurexus
Luxurexus's Avatar
Your nearest Lexus dealership is probably your best place to get information at this point.
Old 01-01-13, 04:26 PM
freegard
freegard's Avatar
Originally Posted by mikes7ke
I don't think many people have had problems with their PNP switch. In fact the closest to a problem I was able to find was someone converting a 98 sc to five speed.
I have a 94 and took the PNP switch out. So I can't help you.
How did you do the electrical bypass so it was not an issue when you removed the switch?
Where is the switch and what else do I need to do when removing the switch?
My car is having an issue that indicates that this switch is preventing it from starting and
rather than dealing with thjis switch I would like to take it out. 94 LS400
alcan
01-30-17 07:11 PM
alcan
01-30-17 05:14 PM
stratman
IS F (2008-2014)
23
07-05-12 09:45 PM
hodog13
GS - 1st Gen (1993-1997)
06-01-09 11:22 AM
mwbuck
RX - 1st Gen (1999-2003)
01-07-04 03:04 PM
Quick Reply: Car will not shift into certain gears (the gearshift wont)
