May Have Front Struts on wrong side
Old 03-29-12, 01:07 PM
Atrofee
Atrofee's Avatar
Default May Have Front Struts on wrong side
I replaced the factory struts because I changed rims/ tires and needed wheel well clearance. Changing them provided 2 inches I needed. I may have the struts backwards(L/R). They were Identical in vertical size. Coil count was lower. Ive read about the upper mount cup being an issue.
Old 03-29-12, 02:58 PM
SpencerT
SpencerT's Avatar
can you provide more information?
when I did my struts, there wasnt a left and a right. They were both the same.
If your mount is on correctly, you should be able to rotate the entire strut assembly untill it fits.
Old 03-29-12, 03:45 PM
xtremex626
xtremex626's Avatar
it doesnt matter if it's left or right. they both should fit interchangeably.
Old 03-29-12, 05:43 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
the regular coil suspension is same on both sides, but different front to rear.
i believe the air suspension units are corner specific though.
Old 05-03-12, 11:27 PM
execlex
execlex's Avatar
Can somebody verify this for the air suspension? I have seen a bunch of maybes but no certainty. I am looking at a used air shock locally on Craig's and he doesn't know which side it came from, he is stating it can be used for either. Anybody?
hippchip
06-26-19 11:00 AM
lexslexus
09-12-17 04:52 PM
davidma415
05-12-17 07:53 AM
Sammour
Suspension
06-03-16 06:54 AM
mixednuts
11-16-07 02:04 PM
Quick Reply: May Have Front Struts on wrong side
