Where is the location of the Fog Light relay 98 ls
My fogs are not working and I have checked everything and all seems OK. The only thing left to check is the fog relay. I cannot figure where the relay is in the fuse box under the hood. None of the labels say fog lights. Any help?
One relay is marked HEAD LP could that be it?
Thanks
OOPS, It's a 99, but I guess it doesn't matter... My 98 is a Land Cruiser...
Thanks
Thanks
Thanks
my fsm(this is for a 95, mind you) says you'll have a much easier time getting to that fuse box if you remove the lower dash bezel(the one with the driver's floor light and alarm beep button). I've gotta do the same thing here soon, cuz my fog lights are MIA as well.
You do need to do that. here is a link to a thread describing how to allow your Fogs to be on w/o the headlights. It describes how to get to the relay and has pics.
https://www.clublexus.com/forums/ls4...omplete-4.html
Go to the last page for additional details and pics. including a short cut .
first , buy 2 new bulbs,
second fog lights only come on with the headlights.
third you can hear the fog light relay click if its working when you turn it on and off ,
fourth if your high beam is on then you have no fog lights
In the area of the fuse box that is on the gas pedal, you must open it and behind it there are 4 fog relays, a power relay, an ignision relay, and one more. Lexus ls400
Thanks
Thanks
