Megan LP vs EZ
My quick search, Megan 12/8 and the BC is 12/10. To soft up front or rear?
Some discussion here: https://www.clublexus.com/forums/sus...ring-rate.html
If one is accustomed to the IS-F than yeah, this is going to feel like your couch let alone the stock springs.
Sorry, but the rears maxed out with a 3-4 1/2" gap between the threads and a 2 finger gap isn't low enough for me. I got my info from a fellow member here who also has a 98-00 and had LP's. He eventually switched them out for D2 coilovers, but now he's on PBM's. Guess who!
Drooping the springs and dropping the preloads is essentially performing the same task which is basically letting the springs hang to go lower since the coils are already maxed out. You do this by unlocking the top 2 collars and lowering the whole spring perch down. Megan states to not droop over 3cm, but I've done 4cm and it's fine. Doing this will compromise shock travel and the rears will become more soft of course.
Not to mention if you are or want to be slammed, you're going to bottom out everywhere even with the max stiffness. I experience this everyday
Not trying to stray people away from Megan products, but I simply got the EZ's cause I'm on a tight budget. If I had money to shell out, I'd get PBM's. But then again, it really depends what your daily applications are.
I'm on a tight budget also. Id much rather have a forward rake then a reverse rake. Idealy would be no rake at all. I like to ride low, but I also like halling *** around corners. I can play with tire sizes to close the gap in the rear and use a lip & side skirts to give the visual aperance of being rilly low.
On the ls and gs, youre more likely to see a reverse rake aka boated because the rear fenders are alot lower than the front fenders. If the gap between the front and rear fenders are the same, you will notice the overall car will already be raked. Most people dump the rears lower than the fronts to even out the rake.
lol.. if you're looking to go "low", you'd want the LP's over the EZ's because if you get the EZ's like i did, you'll have to drop the preloads in the rear in order to be low. the rears maxed out on the EZ's is a two finger gap. the fronts however have no problem going low.
iirc, the LP's are the opposite of the EZ's. fronts can't slam but rears can. either way, the solution to this would be to drop the preloads. or you can avoid that by getting other coils beside megans.
![](https://sphotos.xx.fbcdn.net/hphotos-ash3/537028_419484214732761_100000135591745_1857252_45352033_n.jpg)
^that's with 4cm of droop of the springs in the rear.
So effectively, how much drop was achievable without adjusting the preload?
Having this info for the Megan EZ, LP, BC, D2 is good info for the suspension section of the FAQ.
damn thats not low at all lol i maxed out the rear and am tucking a bit of tire, im on 225/45/18s as well. maybe on the ucf10 it gets you a bit lower then the 20? or maybe just my tire size? haha
