Megan LP vs EZ
I see that there are now two types of Megan coils, the "LP" and the new (to me) "EZ." Anyone know what the deal is here? The "EZ" unit seems to be about $200 less than the "LP."
the LP is valved to be a touch softer and uses proper pillowball upper mounts. rates are 12kg/mm front and 10kg/mm rear
the EZ is the "budget" coilover, uses a slightly stiffer base valving, and uses RUBBER/alum upper mounts. rates are 12kg/mm front and 8kg/mm rear
I'm thinking of going with megan coils. How does the EZ series compair to the LP series? Wich one goes lower? Wich is best for the daily grind. If I get LP's then that'll be that. If I get EZ's ill be using em for about a year or 2 then changing out to BC's.
Platform - 90 LS400 w/ full interier.
The wheels will be ROTA 18x9.5 +35 all around. Not shure on the series of the ROTAs, just know they are a 6 apoke wheel.
lol.. if you're looking to go "low", you'd want the LP's over the EZ's because if you get the EZ's like i did, you'll have to drop the preloads in the rear in order to be low. the rears maxed out on the EZ's is a two finger gap. the fronts however have no problem going low.
iirc, the LP's are the opposite of the EZ's. fronts can't slam but rears can. either way, the solution to this would be to drop the preloads. or you can avoid that by getting other coils beside megans.
both EZ's and LP's are soft. they have the same 12k F / 8k R spring rate. i bottom out everywhere and i'm slammed.
![](https://sphotos.xx.fbcdn.net/hphotos-ash3/537028_419484214732761_100000135591745_1857252_45352033_n.jpg)
^that's with 4cm of droop of the springs in the rear.
idk what the difference really is between the lp and ez, but i have the LPs maxed out and its alright. kinda soft since the spring rates arent the best, but it gets me pretty low i think. haha uca knocking on the shock tower here and there. lol
