Rebuilt
I'm with PD on this one. They are dirt cheap used so unless you were building it for more power (not sure if a kit even exists) it would likely be a waste of your time and money. I'm lazy though, only a real real special car would inspire me to do a full tear down and rebuild.
the motor is well taking care of and it has 220,000 miles and it runs very smooth.
were do you guys think i could find another 1uz.......
im not trying to put more hp on it just trying to make it last longer got any tips besides tune ups..i had it for 4yrs all ready and im very attach to it...
thnkz for your help guys................
If you insist on getting another, check ebay.
If the car is well taken care of, and is running well, then why are you looking to replace/rebuild the engine? With routine maintenance and care you should be good to go. I had my engine replaced in my 92, before I sold it, but I had a bevy of things that needed to be addressed and as PD stated, it would have cost more rebuilding it than to just replace it. 1UZ's, if you insist on replacing, are like water and can be found all over the place. I DO caution you tho,,. The LS400 and the SC400, while both DO use the 1UZ engine under the hood, they are totally different creatures. Outside of the engine block itself as well as the heads, EVERYTHING will have to be transferred to the new engine from your old one. When I say this I mean everything,,oil sump, oil pan, brackets, mounts, you name it, it needs to be transferred. I found out the hard way when I had mine replaced with a moter from an SC400, and we had to transfer everything. I DID all work out in the end, but it was a heck of alot more work than I had planned on doing, so if you DO decide to replace you HAVE to make sure it came out of an LS400 for direct drop in. Just sayn',,,,
