94 LS 400 Woes...need your help.
Old 04-10-12, 12:39 PM
Scorny
Scorny's Avatar
Exclamation 94 LS 400 Woes...need your help.
It all started a couple of weeks back,the 'check engine' light and 'traction off' will come on when I start the car in the morning.
At times the idle will be very rough for about a few minutes,then normalize.The car died(shuts off) twice on me during this fiasco.
All this has stopped until yesterday,the LS now shakes and vibrates when I step on the accelerator and it idles like a motor bike when parked.The RPM does not go up or down and it's not loud either just a very rough idling.
I'm hoping you guys can help me on this before I take it to the mechanic,maybe it's something I can fix myself with a little to no help.
Thanks a lot.
Old 04-10-12, 03:11 PM
GS4_Fiend
GS4_Fiend's Avatar
check for codes. Get a paper clip and short pins TE1 and E1 and count the flashes.
Old 04-16-12, 07:53 AM
ZORLAC
ZORLAC's Avatar
I have a similar problem. Mine seems to only happen after i use the emergency brake. My 96 LS400 runs horrible but seems to work itself out after the car sits for a few hours. No Codes! Dealer said it was fuel pump relay, which i replaced and it didn't solve the problem. Then i was told it was the fuel pump, which i replaced and i still have the problem but only after i use the E-brake.
There has to be someone who has had similar issues on this site and has an answer as to what the issue is!
Old 04-20-12, 06:05 PM
Scorny
Scorny's Avatar
I've changed the spark plugs and wires and it helped drastically.I still get the check engine light and slight hesitation in the idle every now and then and also when the car is moving.
I'm going to clean the throttle body,put in new air filter and report back.
The code I got from the paper clip was '3141'.Hope somebody can offer more help.
Old 04-20-12, 08:01 PM
j2b4o
j2b4o's Avatar
If the plugs and wires were bad it's likely the caps and rotors need to be changed also
Old 04-20-12, 08:21 PM
mikes7ke
mikes7ke's Avatar
31 air flow meter signal
41 throttle position sensor signal
as per http://www.lexls.com/tutorials/intro/codereading.html
Old 04-21-12, 12:49 AM
Scorny
Scorny's Avatar
^^^^^Thanks very much,but base on what the code has pointed out,what am I looking to replace or clean ?
One sound like the throttle body.
Old 04-21-12, 09:16 AM
GS4_Fiend
GS4_Fiend's Avatar
No cleaning involves. You gotta take voltage readings to see if it operating properly and see if its a wiring integrity issue or the component itself.
Prodigy249
11-24-16 06:45 AM
susancraw
11-11-16 10:52 AM
Lex4RDNY
04-17-16 07:05 PM
nambodanny
08-15-10 02:12 PM
bigjrocc
07-24-08 09:38 PM
Quick Reply: 94 LS 400 Woes...need your help.
