EGR Pipe
Old 11-01-02, 05:38 PM
Christian
Christian's Avatar
Default EGR Pipe
Has anyone ever changed the EGR-Pipe in the first genereation LS 400? Mine is broken at the flexible part, that causes a louder running engine. The dealers manual says 6.8 hours to change it!!!
Any experience with it?
Thanks Chris
Old 11-01-02, 06:06 PM
Lexozz
Lexozz's Avatar
I had mine changed about a month ago. You're lucky if it only takes 6.8 hrs, I did not have my car for 2 long days. I had the same nasty sound you're probably getting right now, it's a little pipe but it's hell to get it out. The EGR pipe is located behind the engine connected from the back to the exhaust pipe. You difinitely have to get to it from underneath...good luck...
Old 11-01-02, 06:17 PM
Sooner
Sooner's Avatar
sure i do them all the time im sorry if u have to do it on the ground but with a rack there are some tricks and you can do them fast
Old 11-01-02, 06:58 PM
Lexozz
Lexozz's Avatar
How fast? and what are the tricks? Pleazzz let me know!
Old 11-01-02, 07:11 PM
Christian
Christian's Avatar
Yeah let me knoe the tricks. My mechanic will do it for me in the garage.
Old 11-02-02, 02:24 AM
LexieLS
LexieLS's Avatar
Default what sound?
What kind of noise would it make??
Old 11-02-02, 03:07 AM
Sooner
Sooner's Avatar
i can do them in 20-30 minures on 90-94 non california cars and 95-97 in 35
Old 11-04-02, 09:36 AM
Lexozz
Lexozz's Avatar
Are you going to let us know what are the tricks to doing that job in such short time?
Old 11-04-02, 09:40 AM
Lexozz
Lexozz's Avatar
Default Re: what sound?
It sounds like an exhast leak coming from the front, right belew the manifold, it's the EGR pipe!
Old 11-07-02, 07:46 AM
Christian
Christian's Avatar
Lexozz, why are you telling us you can do the job in 20-30 min and don't tell us how.
Chris
Old 11-07-02, 09:51 AM
Lexozz
Lexozz's Avatar
Chris
Dude it was sooner who made that post not me, I'm also waiting for a response.
Old 11-08-02, 01:15 PM
Christian
Christian's Avatar
Sorry, my fault.
Old 11-19-02, 01:28 PM
djr73999
djr73999's Avatar
Had the EGR Pipe replaced at Lex dealer, took them 4 plus hrs,
boy that crackling sound was horrible sounds like a busted muffler
I also would like to know about that 20-30 minutes statement.
dj
Old 11-19-02, 01:52 PM
Lexozz
Lexozz's Avatar
Exclamation EGR pipe Procedure!
Sooner pm'd me with these instructions:
You drop the exhaust from the cats and remove the r/h cat there are 2 12 mm nuts holding the lower part of the pipe on and then there are 2 12 mm bolts that go through the pipe to the lower coolant bypass then itll come out and the install the gasket on the top and one on the bottom lining up the top bolts will be tricky make sure they are in straight and then reinstall.
Old 11-21-02, 11:52 AM
Christian
Christian's Avatar
Great, I hope it will work. Thank you.
Quick Reply: EGR Pipe
