white smoke on start up???
Old 05-01-12, 05:12 PM
dougie23
dougie23's Avatar
Default white smoke on start up???
im getting white smoke on start up? only on start up!!! nothing else what can it be?
Old 05-01-12, 07:23 PM
FrankReynoldsCPA
FrankReynoldsCPA's Avatar
My best guess is you've got a head gasket issue, and you're getting coolant in your engine. That's just a guess though.
I don't know if it applies to gas engines, but I know EGR issues on diesels can cause white smoke.
Old 05-01-12, 08:20 PM
PerpLexusd
PerpLexusd's Avatar
That's usually a result if the idle air control valve located under the power steering pump going bad. It leaks power steering fluid into the intake manifold and causes a big white cloud on startup that usually clears after a minute or two. I think there's a write up on lexls.com on how to replace our just get rid of it. If not there,the are some tutorials on here how to do it .not a very tough job
Old 05-01-12, 08:27 PM
GS4_Fiend
GS4_Fiend's Avatar
How much is it smoking? Post a video. If it's just light smoke, it's normal. It's condensation early morning.
Old 05-01-12, 09:47 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
sounds like this. please read the 1st gen sticky or whatever sticky applies since you DIDNT POST YOUR YEAR
CManolo
07-14-15 12:19 PM
OMAHA
01-10-14 04:56 PM
attzor
Performance & Maintenance
12
10-10-12 06:55 PM
W92ls400
03-31-07 01:16 AM
Suneet
01-07-07 03:25 AM
Quick Reply: white smoke on start up???
