94 ls400 smoke from the two center vents
Old 05-07-12, 02:04 PM
1ciscokid
1ciscokid's Avatar
Default 94 ls400 smoke from the two center vents
the other day i noticed lite smoke coming from the two center vents! didnt smell like fire! i turned the car off & restarted it.. still smoke! turned the a/c on smoke went away! any idea what could cause this?? thanks
Old 05-07-12, 03:05 PM
BobN54
BobN54's Avatar
Any coolant odor? Inside windows fog up easily? If so, that is a symptom of leaking heater core. If it occurs after AC is turned off, when it has been running for a good while, it can be a symptom of water vapor due to the coil icing up from an AC problem. If it is actually smoke and not vapor, I dunno!
Old 05-07-12, 03:11 PM
1ciscokid
1ciscokid's Avatar
the passenger side window has fog! even when the ac is off .. no odor!!
Old 05-09-12, 01:53 PM
steve2006
steve2006's Avatar
It sounds like your AC evaporator is freezing up, have you had the AC charge checked?
Also when was the last time you replaced the pollen filter?
Old 05-09-12, 06:13 PM
python
python's Avatar
no cabin filter in a 94..sorry
Old 05-10-12, 09:57 AM
1ciscokid
1ciscokid's Avatar
never checked! i just got this car! its been sitting for 3yrs
Old 05-10-12, 12:45 PM
steve2006
steve2006's Avatar
Didn't realise all the 93-94 models didn't have them, mine does but it is a 94 JDM Celsior.
ruetzal
IS - 1st Gen (2001-2005)
08-12-10 04:23 PM
Coconut
12-08-08 01:28 PM
swat1727
05-20-08 07:38 PM
norcalf430
03-22-08 10:50 AM
EllenRX
RX - 1st Gen (1999-2003)
08-23-06 07:33 AM
Quick Reply: 94 ls400 smoke from the two center vents
