what parts to take off 94 ls400
Family member getting rid of 94 ls400. What parts should be stripping off this? i have a 91 ls400 so some parts do and dont fit but if you were going to dismantle what would you take off to have and keep around?
Thanks
Thanks
^^^ Concur with the above. just about ALL of the body parts will fit, lighting, etc. 93/94 model only received minor upgrades over the pre-94 models. Some of the electronics may be a little different in the plug configuration, but you could just about go to town stripping the car.
http://www.lexls.com/info/lsgenerations.html
Things usually first to go from JY cars;
ECU
Speedo cluster
AC display
Seatbelts (if they fully retract and are tan)
Fuel sender
Power steering pump if not leaking
Power steering rack if not leaking
Steering wheel/seats/armrest if leather is good
Floormats if not torn or frayed (can be redyed)
Keys, door cylinders, ignition cylinder, trunk cylinder, glovebox door and door sender unit if he has the original remote keys
Driver door lock actuator if it works
Under body tray
ECU
Speedo cluster
AC display
Fuel sender
Under body tray
