Under carriage shield
Old 01-06-13, 07:47 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
Originally Posted by johnnyg66
Well 1/8 in is a 30 gauge sheet. That is very thin but easy to bend. You probably want a little thicker metal. If you can cut and bend yourself than great. You could crawl under the car and make your own template with cardboard. Take it to a fab shop and determine what size sheet to use than.
1/8" is NOT 30gauge steel, it's 10 or 11gauge (depending on the type of steel), or 8 Gauge in aluminum sheet.
the steel will require mechanical effort to bend, the aluminum MIGHT be doable by hand, but i'd want a machine to get the nice clean bends anyways.
Old 01-06-13, 08:28 PM
SynicalVip
SynicalVip's Avatar
Link didn't work well not on my iPhone at least lol
Old 01-06-13, 08:46 PM
sam12345
sam12345's Avatar
Or to make your own idea and material starters
http://www.miataturbo.net/race-prep-...ro-pics-63769/
Best material to use
http://www.trackpedia.com/forums/showthread.php?t=4517
http://www.laminatorsinc.com/sign-pa...ucts/alumalite
U can get it at a sign making shop or
http://www.alumilite.com/Dealers.cfm?State=CA
Old 01-06-13, 09:54 PM
PureDrifter
BahHumBug
alumalight and cloroplast work great when you want a cover, but are very thin and prone to damage, so not the best choice for a skid plate that you want to protect your oil pan .
a skid plate is better for lowered cars, alumalite/plastiboard if you're not that low or stock height and want a better/bigger cover than stock.
Old 01-07-13, 01:54 AM
Shiryo
Shiryo's Avatar
You want a minimum of 1/5" (4.8mm) for a skidplate.
I have a skidplate on my VW since it's slammed pretty low on coilovers and have hit damned near anything and have accidentally launched the car off all 4 wheels, bottoming out the skidplate onto the highway more than once. Also saved me from one of those huge thick metal bolts that holds down those thick metal road plates that wasn't properly seated.
So yes. 5mm is perfect.
Old 01-07-13, 05:26 AM
sam12345
sam12345's Avatar
In that case the stock undercover is no good either
Use the skids I saw someone do on thi or the GS forum
https://www.clublexus.com/forums/gs-...e-project.html
Old 01-07-13, 05:50 AM
johnnyg66
johnnyg66's Avatar
YEP, Sorry i added another zero in front of the conversion to inches.
Old 01-07-13, 10:33 AM
RA40
Super Moderator
RA40's Avatar
ABS and similar thermo plastics work sufficiently and are easy to work with minimal tools. Saber/jig saw, bandsaw, drill and heat gun. They will deform on impact so unless it is a hard heavy hit, these will be reasonably resilient.
Old 01-07-13, 02:00 PM
Shiryo
Shiryo's Avatar
A non-metal skidplate... This thread just made no sense, no offense. We're talking about saving the life of your engine. Any reasonable tap of a non-metal skidplate would shatter.
Old 01-07-13, 02:30 PM
PureDrifter
BahHumBug
not so much, if you made one out of say 1/4" delrin i'm sure it would take some abuse, plus it wouldnt sound as bad as a metal one.
but this thread is technically about a lower engine cover, not a skid plate
Old 01-07-13, 03:00 PM
midwest2
midwest2's Avatar
If anyone was close to Nebraska they could have mine. I never reinstalled it. While I'm sure this cover is not completely worthless, it's damn close. I just don't want to remove it every time I change the oil in my 400. And at 20k miles a yr, it gets changed plenty. All my newer Lexus vehicles have access points for the oil filter which makes it much nicer.
96 LS400
2003 LS430
2000 LX470
Old 01-07-13, 04:03 PM
bobafreak
bobafreak's Avatar
Or you can drive around, look for a aluminum construction sign, take it home, mock it to the chasis and walla home made construction skid plate. I used to make them all the time for my s13. They held pretty well and its easy to bend and durable. Timmy let me borrow yours so i can do it the easy sleazy lazy way and mock yours and get a diamond bling bling silvaarzzz 1ne.
Old 01-07-13, 04:35 PM
timmy0tool
timmy0tool's Avatar
haha sorry guys, i actually took that pic off another member's thread (i believe it's a silver 98-up with 18" Works and a single exit exhaust from AZ). i don't actually have a plate like that in my possession. after reading my post, it does sound like i own one. apologies, and credit to the real owner!
Old 01-07-13, 06:48 PM
sam12345
sam12345's Avatar
That's what alum alitte is the same thing they make signs out of
Old 01-07-13, 07:31 PM
bobafreak
bobafreak's Avatar
Except my idea was for the price of free 99. But i am not responsible for local authority's fining you for it. Jusss sayiingggg.
Quick Reply: Under carriage shield
