Under carriage shield
Old 05-21-12, 08:42 AM
breezy0318
breezy0318's Avatar
Default Under carriage shield
Does anyone knows the name for the plastic shield underneath car by engine & oil pan. Mine is torn in half and I want to buy new one
Old 05-21-12, 09:40 AM
timmy0tool
timmy0tool's Avatar
it's called an engine undercover.
51441 5144150030
ENGINE UNDER COVER NO.1
Old 05-21-12, 12:48 PM
johnnyg66
johnnyg66's Avatar
yep. I bought mine from sewell lots of $$ for a piece of abs plastic.
Old 05-21-12, 03:33 PM
timmy0tool
timmy0tool's Avatar
any chance obtaining one from your local junkyard? this piece is rather important, protecting the pan and directing airflow properly under the car. you can always just make one!
for the SLAMMED folks! diamond plate.
Old 05-21-12, 03:58 PM
ocr
ocr's Avatar
That's what I'm gona do, or I'm just going to use steel platting.
Old 05-21-12, 04:29 PM
sleepywgn
sleepywgn's Avatar
I have one!!! 50 bucks for it! PM me!
Old 01-05-13, 09:45 PM
LScowboyLS
LScowboyLS's Avatar
where can I purchase this already cut to fit and ready to bolt up?
Old 01-05-13, 09:48 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
you can't, timmy0tool's was a one off and no manufacturer makes them.
that being said, any fab shop (off-road or otherwise) should be able to make one with minimal effort.
Old 01-05-13, 09:57 PM
SynicalVip
SynicalVip's Avatar
The one shown in above pictures, look like they just get a metal plate to its size, cut it a but then screw it on. Can actually see a few screws that are use to hold it up
Old 01-05-13, 10:15 PM
LScowboyLS
LScowboyLS's Avatar
it's more than just cutting, it needs strategic bends to duplicate the plastic part it's replacing
Old 01-06-13, 08:35 AM
johnnyg66
johnnyg66's Avatar
Use your plastic one as a template.
Old 01-06-13, 10:20 AM
RA40
Super Moderator
RA40's Avatar
The diamond plate is nice. The metal supply out here sells 1/8" which is pretty thick though I haven't been in to see if there is thinner stock available. The under cover if bought from your dealer is ~$135. Unless one is going off road, purposely hitting every tire casing or debris on the road or driving through 4"+ puddles of water, the plastic is pretty durable.
Old 01-06-13, 11:53 AM
SynicalVip
SynicalVip's Avatar
About how thick the metal plate should be? I no longer have the one under the car engine that's why I wanting to custom a metal one and while I'm there I mind as well do the one covering up the catalytic converter etc
Old 01-06-13, 02:18 PM
johnnyg66
johnnyg66's Avatar
Well 1/8 in is a 30 gauge sheet. That is very thin but easy to bend. You probably want a little thicker metal. If you can cut and bend yourself than great. You could crawl under the car and make your own template with cardboard. Take it to a fab shop and determine what size sheet to use than.
Old 01-06-13, 05:50 PM
LScowboyLS
LScowboyLS's Avatar
Timmy's looks a lot heavier than 30 gauge - the tough stuff will require a machine to bend it!
Quick Reply: Under carriage shield
