2000 Lexus LS400 'sighing' while driving problem.
Old 05-29-12, 03:37 PM
LilBit
LilBit's Avatar
Default 2000 Lexus LS400 'sighing' while driving problem.
Hi all. Yes, I said sighing. It's not choking, it's not quitting, it's not stalling, it's not tripping a check engine code or anything. I'll be toodling along, and then all of a sudden, for no reason at all, it's like the engine sighs. It just sighs, for a split second, and then continues running without any loss of momentum. Almost like it quits getting fuel for just a split second. It does it randomly. Sometimes I'll have cruise on, others I won't. It doesn't kick the cruise control off when it does it, either. Sometimes I'll be accelerating, sometimes I won't. It usually happens when I've been driving for more than 45 minutes, and always happens on the interstate. I am not experiencing any loss of power, or loss in fuel mileage.
What could it be?? And should I be worried? I have 267,000 miles on it, and the timing belt and components and head gaskets were replaced about 15,000 miles ago.
Old 05-29-12, 05:12 PM
cobalt91
cobalt91's Avatar
Any drop in rpm?
Old 05-29-12, 06:22 PM
LilBit
LilBit's Avatar
Nope. It's literally a split second. Just sort of like a 'thunk' type moment of...well... nothing. I know it sounds weird, but I don't have a clue what's going on, and it's so sporadic. No codes, and I plugged up both the Snap-on MT2500 and the Pegisys and neither are picking up anything weird.
Old 05-30-12, 02:31 AM
j2b4o
j2b4o's Avatar
Does it matter how much fuel you have in the tank?? Your sure the rpm's don't drop when this happens?? What does it do if the rpm's don't drop?? Rpms just stay where they were but the car starts to slow??Cars don't really exhale so sighing isnt a great way to describe it, gotta be more specific.
Old 05-30-12, 06:30 AM
91LS400vgb
91LS400vgb's Avatar
That's a tough one. It seems like some sensor is having an intermittent issue - did you have the scan tool connected while the condition was present? I would try to capture the data during the event and look for some evidence in the data streams.
Old 05-30-12, 06:32 PM
LilBit
LilBit's Avatar
It won't do it while the computer is attached. It's like it knows... And I guess if you wouldn't call it a sigh, then a hic, like half a hiccup. It's a very very split second. As for fuel level, doesn't matter. Usually has plenty of fuel as I don't like to go below half a tank, living in rural WV.
Old 05-30-12, 06:47 PM
mikes7ke
mikes7ke's Avatar
I can't visualize the problem from the description. Though it would be comical if you were driving too fast and the noise was the traction control. By the way, have you ever been low on gas and heard banjos?
Old 05-30-12, 07:08 PM
LilBit
LilBit's Avatar
No. I'm happy to say I haven't.
Old 05-30-12, 07:36 PM
ArmyofOne
Dysfunctional Veteran
ArmyofOne's Avatar
Lilbit, I have a theory...and I think its plausible. Bear with me here.
Power steering pump. How is your fluid level? Sometimes if the fluid level is low enough (or you have a leak somewhere), it can suck air into the system, causing sort of a hiccup. Followed by a whining noise. Then if there is fluid reintroduced to the system (hit a bump for instance), it all goes back to normal.
Just a guess, without actually being there, I cannot TRULY diagnose the car. I will PM cody with this thread and get him in here, as he is better versed in the LS than I am.
Old 05-30-12, 09:38 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
throttle position sensor has a dead spot in it...
chances are if you take your time with a voltmeter or your Snapon/Genisys scanner, you will see a rapid change in voltage at one spot - it may only do it when it is hot or cold as well, so it may be difficult to find...
there are other possibilities, but I've seen this one first hand, and can even duplicate it if I want to when tuning my IS300 - leave a hole in the throttle table and it does exactly as you describe...
Old 05-31-12, 01:47 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
Mitsuguy in the LS forum? AWESOME! lolol
Old 05-31-12, 08:02 AM
mitsuguy
mitsuguy's Avatar
I saw the bat signal...
Old 05-31-12, 11:11 AM
timmy0tool
timmy0tool's Avatar
whoa, good answer! never would have considered the TPS.
Old 05-31-12, 07:10 PM
LilBit
LilBit's Avatar
I didn't think about the tps, and actually, I DO have a power steering leak. So I'll fix both of those, and see if that fixes it! I'll let you guys know!
raydleoni
Maintenance
25
07-08-21 04:33 PM
GenericUse
08-08-18 05:08 PM
donreilly
06-18-17 09:17 AM
ychen
28
04-30-17 06:57 AM
ttyR2
09-14-08 07:32 AM
Quick Reply: 2000 Lexus LS400 'sighing' while driving problem.
