92 rear brake help??
hello to all,heres my situation, last week i been hearing like i grinding noise on my passenger rear,mostly when i turn left i hear that noise,now when i turn into my driveway i turn in right i fell like theres air in my lines but doesnt do that when i turnleft then brake???? now JUST now comming home from the store i had to push my brakes all the way to the floor and noticed brake fluid in my inner wheels?
ok i had just went out and tryed to find out whats wrong,i took some pics so you guys could probly help out to.heres the first pic when i took off the rim,it seemed fine
![](http://i47.tinypic.com/28vagt3.jpg)
so what do i need to fix this problem?? so i need new brake pads,is the brake caliper bolt/guide pin is what i need to secure the caliper down on the other side? then get moe fluid so i can bleed brakes and i should be fixed right????
whoa! that is a major problem! is the piston still in there? i can't see it. def get new pads (replace all 4 in the rear), and get a replacement bolt. i would install all that, add new fluid, bleed, then check to see if the piston is still leaking. the missing pad could have damaged the piston seal, and it will constantly leak fluid. it may need to be rebuilt. good luck!
