Rear Differential Subframe ALLEN BOLT SIZE?
Hello, I am trying to take off the differential on my 1997 LS400 but I do not have an allen tool big enough for the two rear mounting bolts. Do any of you know the allen size for these two bolts? They are quite big in size! Thanks!
Well, I took off the complete rear subframe before I removed the rear differential. As for taking off the rear diff while it's still installed in the car, I cannot say how difficult it exactly is. Taking off the rear subframe took me about an hour and a half and it was quite difficult because there was a lot to remove.
to undo the rear diff probably take 1 hour. it wasn't too difficult.
on 95 ls400 there was 3 bolt to undo differential from subframe and 5 botls to undo the two axles from the diff and another 4 bolts to undo drive shaft.
Maybenow1
IS F (2008-2014)
07-10-13 05:50 PM
