i have a exhaust question
Old 06-26-12, 02:30 PM
bstains
bstains's Avatar
Default i have a exhaust question
I need a little help, I have a 2000 ls400 and my check engine light is on and the codes read bank 1 catalytic converter. I was told that the bank 1 side is the passenger side, does anyone know where i can get a quality aftermarket converter and could a oxygen sensor be tripping the code instead of the converter really being the problem.
thanks
bstains
Old 06-26-12, 03:34 PM
billydpowe
billydpowe's Avatar
it is highly unlikely that you have a bad cat... they should last the life of the car, you probably have something out of range giving you a bad signal.. your air flow, fuel mixture, plugs and everything that feeds your exhaust is suspect. Have a good scan ran on it... you should have some Ky buddies up there that will help you.. how many miles on it??
Old 06-26-12, 07:22 PM
AYEmike
AYEmike's Avatar
you have an exhaust leak somewhere around the gaskets of the cat
Old 06-27-12, 11:21 AM
timmy0tool
timmy0tool's Avatar
i thought bank 1 was the driver's side ?
Old 06-27-12, 12:32 PM
billydpowe
billydpowe's Avatar
this is true, bank one is the driver side... on american cars.
Old 06-27-12, 12:50 PM
Kaiyin
Kaiyin's Avatar
this. I got the same code after I scraped enough of my exhaust to create a small crack before the o2 sensor.
Old 06-27-12, 02:16 PM
bstains
bstains's Avatar
Default exhaust question
The check engine light is on again off again. Thanks for the information, ill have the exhaust looked at for a leak. The car has 145000 on it, runs like a champ though.
steveo55
Performance
07-20-24 09:35 AM
MashinA
Performance
31
01-04-18 11:52 AM
peafarmer
05-15-15 08:16 AM
CMinner
05-09-13 08:40 PM
hypervish
RX - 1st Gen (1999-2003)
02-04-12 05:29 AM
Quick Reply: i have a exhaust question
