1993 LS400 Rapid Gear Hunting - TPS?
Old 07-03-12, 01:32 AM
AW11SD37
AW11SD37's Avatar
Default 1993 LS400 Rapid Gear Hunting - TPS?
Hi all,
I did a thorough search on existing topics, I'm sorry if I missed an existing answer.
First, a little background - I know I have a bad throttle position sensor, as the traction control is disabled and CEL is on. I just did a transmission fluid/filter change and it hasn't remedied the problem. I'm hoping it's due to the TPS but fear it may be a bad trans.
The car shifts as normal up to about 55 MPH or so. The issue arises when trying to pass this speed or when downshifting to pass or accelerate - the trans will very rapidly shift between 3rd and 4th, staying engaged in either gear for what feels like less than a second. Once you lift or slow down, the problem disappears. Any hope that this may be related to the TPS or does it sound like a bad transmission? Thanks in advance for any help. Please let me know if more detail is needed.
AdamOj
GS - 1st Gen (1993-1997)
11-19-14 05:07 PM
xxdc2xx
24
12-30-11 03:09 PM
RSTSpeed
Performance & Maintenance
18
07-26-11 04:07 PM
JAndersson
07-01-11 02:11 AM
thebuckama
02-06-09 10:31 AM
Quick Reply: 1993 LS400 Rapid Gear Hunting - TPS?
