Need Advice - suspension "swaying"
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
I have this swaying issue no matter how fast i'm going! it's very bad at speeds over 40mph. I haven't changed the tires yet but I was told that the sway bar bushings would cause that. I changed them out today and no change in the swaying. I am so frustrated with this car does anyone know how to solve this???
94 LS 400 sways from side to side as soon as i get over 30mph. It doesn't happen all the time but quite often. I changed out the rear way bar links; because it only happens in the rear but that changed nothing. I did notice that the boot on my drivers rear axle was busted, could that have anything to do with it? I have seen posts about the tires could do it also, there are so many posts about what it could be I just need some clarification. It's only in the rear mainly on the drivers side.
My 90 LS had a very slight wander above 50mph in a gradual turn. I would have to make very minor corrections throughout the turn to keep the same track between the lines. Yesterday I replaced both strut rod bushings and the sway is gone and the car tracks straight and true( my clunking is gone also). I realize the strut rod is different on the 95+ cars but it would be worth a look IMO.
Honestly the shocks look like the originals. I just bought this car so I'm just trying to get a feel for it. I have never owned one before so I'm learning as I go. The tires are a definite issue none of them are the same so that's one issue. Looking at the rear as the car sits the rear shocks do look like they are gone. So i'm going to start with shocks and tires and go from there.
Shocks are fine on vehicle they actually have been replaced. What I did notice was that the wobble is only on the driver's rear. The wheel seems to be angled in at the top and bottom pushed out, so I'm guessing something with the alignment. maybe an axle??? The boot is broken on that axle. I think i'm going to take it somewhere so that they can check my alignment maybe see if something is broken or loose.
Originally Posted by kenji815
i notice the stock shocks are very floaty and make the car handle very very bad.
i think set of coilover will fix the problem.
Posted from ClubLexus.com App for Android
