3rd Drain Plug
Old 11-13-02, 07:16 PM
gebo
gebo's Avatar
Default 3rd Drain Plug
Does anyone know how to find the 3rd coolant drain plug near the top of the V8? In the service manual, the picture shows one drain plug at the bottom of the radiator, one drain plug on the driver's side of the engine, and another near the top of the engine beside the filler plug towards the driver's side of the engine. Fantomd put some great picutures in the thread "removing the outside rear view mirror glass." It's just that I still can't find the dadgum thing. Even with a picture. Are there any mechanics that can interpret the picture for me???? Please....
Old 11-14-02, 06:44 PM
rybikowsky
rybikowsky's Avatar
There are two block drain plugs one on the left and one on the right both near the fronts.When I changed my coolant.I only removed one of the block pluga.seems to have drained ok.
Old 11-15-02, 12:30 AM
lexie
lexie's Avatar
Default coolant change
I plan to drain my coolant from the radiator drain **** and refill . Do U know how many percent of the coolant are being changed this way? Is this good enough? or should I ask the dealer to flush it which cost a lot :eek:
Oh By the way anybody know where is the '91 LS engine drain plug located?
Old 11-15-02, 09:37 AM
Lexozz
Lexozz's Avatar
Default Re: coolant change
Draining the radiator is not enough, all the engines are about the same up until 97. There is a drain plug on the side of the engine (drivers) side.... check out all the pics in the following thread:
https://www.clublexus.com/forums/sho...threadid=63562
Old 11-15-02, 04:55 PM
gebo
gebo's Avatar
Lexozz,
Where is that top drain ****? The one that appears to be beside the filler cap.
Old 11-15-02, 05:37 PM
gottahaveit2
gottahaveit2's Avatar
Gebo:
from your post:
"In the service manual, the picture shows one drain plug at the bottom of the radiator, one drain plug on the driver's side of the engine, and another near the top of the engine beside the filler plug towards the driver's side of the engine."
It's not up near the top beside the filler plug, as you are interpreting the drawing, it's down on the block, it's just that perspective view is misleading.
Both the plugs on the block are about the same level, on the cylinder wall/block area; a long extension and socket will run right through some things and gets the drivers side, while on the pass side, you can see it pretty clearly and use a wrench.
It's easy and I recommend draining all the plugs to get the most old antifreeze out. One thing I learned was be sure to fill up in the filler hole, and also really fill the reservoir so that when the system starts up that air pocket comes out, it took a while on mine. Maybe leaving the drains slightly open while filling then closing them when new fluid starts drippping will burp the air easier.
Sunseek
05-12-19 06:25 PM
saudiboy
RX - 1st Gen (1999-2003)
11-23-15 05:28 PM
gtstcactus
04-02-14 06:32 AM
jsimms2
Performance & Maintenance
03-21-13 07:30 PM
Lexarse
Maintenance
07-21-05 08:27 AM
Quick Reply: 3rd Drain Plug
