Oil drain refill w/ filter = 4.7liters?
Old 08-02-12, 03:43 PM
flipmode64
flipmode64's Avatar
Question Oil drain refill w/ filter = 4.7liters?
Manual states 5.3 liters (1991 ls400) with filter and 5.0 without filter.
I drained into oil bucket and then put it back into a jug with a see through liter reading on the side. Added up to 4.7 liters.
I put the same amount back into the car but is this correct? The dipstick is a pain in the *** to read too on a fresh change!
any tips?
Old 08-02-12, 03:53 PM
SpencerT
SpencerT's Avatar
was your car parked at an angle when you drained?
Old 08-02-12, 05:24 PM
midwest2
midwest2's Avatar
any tips?
After you drain it, add back what the manual tells you to and you can't go wrong. You can read the stick with fresh oil, you just have to have good light to see the oil. Change the filter every time.
Old 08-02-12, 06:35 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
added "oil" into the title.
I usually end up using 5.3-5.5 in my '99 LS, with filter change.
Old 08-02-12, 08:26 PM
cdasilva
cdasilva's Avatar
Was it really cold outside? Usually the whether plays a big role on the oil consistance. By the way remember some oils may burn and or become stuck in components in your engine depending on how often you do oils change and driving condition. Many factories are taking into consideration on how many qts to use.
Old 08-02-12, 08:27 PM
Dirtybrd
Dirtybrd's Avatar
Remember the fliter has absorbed oil in the media also
Old 08-02-12, 11:48 PM
j2b4o
j2b4o's Avatar
Just did a change w/filter in my 90 and it took 5.5 quarts exactly. I wait a while for everything to drain, shake the car up and down and wait some more.
azncapcom
06-15-20 06:51 AM
JerzeeB
05-26-11 02:03 PM
lilbluu
06-01-10 03:44 AM
gary1944
HS 250h Model (2010-2012)
04-14-10 01:49 PM
wakaru8
12-23-09 08:07 AM
Quick Reply: Oil drain refill w/ filter = 4.7liters?
